RTOS on iMXRT1064
RTOS on iMXRT1064
anujtanksali
I am currently working on a project which used bare metal i.e. no OS. I am using iMXRT1064 MCU. I wanted to use RTOS instead of bare metal. Where can I find the RTOS examples on iMXRT1064 device.
Thanks & Regards
Anuj
kerryzhou
Hi @anujtanksali ,
  Follow me, download the RT1064 SDK code which contains the freertos.
Our SDK already contains a lot of freertos code:
https://mcuxpresso.nxp.com/en/builder?hw=EVK-MIMXRT1064
Must select ALL, then download the sdk code, you will find the freertos code in folder:
SDK_2_11_1_EVK-MIMXRT1064\boards\evkmimxrt1064\rtos_examples
Wish it helps you!
Kerry
