RT1176 cm7 rogram received signal SIGHUP, Hangup.
kojimiura
I'm debugging on a custom RT1176 board.
Debugging the SDK sample 'evkbmimxrt1170_iled_blinky_cm4' works without problems.
However, when I try to debug the SDK sample 'evkbmimxrt1170_iled_blinky_cm7',
the following message appears and it fails to run correctly:
Program received signal SIGHUP, Hangup.
0x00254330 in ?? ()
warning: Could not fetch required XPSR content. Further unwinding is impossible.
What is the difference between cm4 and cm7 that makes it work or not?
Any advice would be greatly appreciated.
kojimiura
EdwinHz
Hi @kojimiura,
I'm glad you were able to resolve the issue using information shared by my colleagues.
If you have any further questions about this topic, or encounter any other issues regarding the programming of the CM7, do not hesitate on letting me know.
BR,
Edwin.
%3CLINGO-SUB%20id%3D%22lingo-sub-2370177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERT1176%20cm7%20rogram%20received%20signal%20SIGHUP%2C%20Hangup.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2370177%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI'm%20debugging%20on%20a%20custom%20RT1176%20board.%3CBR%20%2F%3EDebugging%20the%20SDK%20sample%20'evkbmimxrt1170_iled_blinky_cm4'%20works%20without%20problems.%3CBR%20%2F%3EHowever%2C%20when%20I%20try%20to%20debug%20the%20SDK%20sample%20'evkbmimxrt1170_iled_blinky_cm7'%2C%3CBR%20%2F%3Ethe%20following%20message%20appears%20and%20it%20fails%20to%20run%20correctly%3A%3CBR%20%2F%3E------------------------------------------------------------%3CBR%20%2F%3EProgram%20received%20signal%20SIGHUP%2C%20Hangup.%3CBR%20%2F%3E0x00254330%20in%20%3F%3F%20()%3CBR%20%2F%3Ewarning%3A%20Could%20not%20fetch%20required%20XPSR%20content.%20Further%20unwinding%20is%20impossible.%3CBR%20%2F%3E------------------------------------------------------------%3CBR%20%2F%3EWhat%20is%20the%20difference%20between%20cm4%20and%20cm7%20that%20makes%20it%20work%20or%20not%3F%3CBR%20%2F%3EAny%20advice%20would%20be%20greatly%20appreciated.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2371438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1176%20cm7%20rogram%20received%20signal%20SIGHUP%2C%20Hangup.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2371438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F138918%22%20target%3D%22_blank%22%3E%40kojimiura%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EI'm%20glad%20you%20were%20able%20to%20resolve%20the%20issue%20using%20information%20shared%20by%20my%20colleagues.%3C%2FP%3E%0A%3CP%3EIf%20you%20have%20any%20further%20questions%20about%20this%20topic%2C%20or%20encounter%20any%20other%20issues%20regarding%20the%20programming%20of%20the%20CM7%2C%20do%20not%20hesitate%20on%20letting%20me%20know.%3C%2FP%3E%0A%3CP%3EBR%2C%3CBR%20%2F%3EEdwin.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2370472%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1176%20cm7%20rogram%20received%20signal%20SIGHUP%2C%20Hangup.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2370472%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20answer%20was%20helpful.%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-RT-Crossover-MCUs%2FUnable-to-Program-M7-Project-on-i-MX-RT1170-with-MCUXpresso-IDE%2Ftd-p%2F2072769%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-RT-Crossover-MCUs%2FUnable-to-Program-M7-Project-on-i-MX-RT1170-with-MCUXpresso-IDE%2Ftd-p%2F2072769%3C%2FA%3E%3C%2FP%3E%3CP%3EThank%20you.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
