RT106x web service heap size issue.
751 次查看
StephenYeh
Hi Sir
Would you have any idea how to release the heap size after web service?
BRs.
1 回复
715 次查看
kerryzhou
Hi @StephenYeh ,
   When you apply for the heap size, after you use it, you can free it.
  Take an example for the heap apply and release:
int main() {
  int a;
  int *p;
  p = (int *)malloc(sizeof(int));
  free(p);
  return 0;
So, if you want to release the heap size  after web service, you can use free to release it.
Wish it helps you!
Kerry
