RT1062 SAI MCLK input as master
575 次查看
mojolabs
I'm attempting to use SAI1 on the RT1062 as an I2S master for transmit while using MCLK as an input from external clock source on the 1060 EVKB. I have SAI1 on the RT1062 working as an I2S master using MCLK generated from the internal PLL, and can see the MCLK output on pin 1 of J23, which is signal GPIO_AD_B1_09, as well as BCLK, etc on the same header.
I'm understanding from this thread:
https://community.nxp.com/t5/i-MX-Processors/SAI1-MCLK1-source-select/m-p/1435023
That I can use that same pin as MCLK input. I'm changing these register fields (p326-327 in RM):
- SAI1_MCLK1_SEL in IOMUXC_GPR_GPR1 - change from 000 to 011 to select MCLK pin
- SAI1_MCLK1_DIR in IOMUXC_GPR_GPR1 - change from 1 to 0 to select MCLK as an input
And, IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_09 is set to 3 in both cases, selecting AD_B1_09 to the MCLK function.
When I do this, and provide an external clock signal to pin 1 on of J23, I do not see I2S output however - no BCLK generation, etc.
Is there another register change that needs to happen to select MCLK as an input for I2S master transmission?
1 回复
467 次查看
EdwinHz
Hi @mojolabs,
I have provided an answer on the latest post you did here: RT1062 SAI MCLK input as master - NXP Community
I will continue supporting you on that post if needed!
BR,
Edwin.
%3CLINGO-SUB%20id%3D%22lingo-sub-2366982%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERT1062%20SAI%20MCLK%20%E4%BD%9C%E4%B8%BA%E4%B8%BB%E6%8E%A7%E8%BE%93%E5%85%A5%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2366982%22%20slang%3D%22en-US%22%20mode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href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FSAI1-MCLK1-source-select%2Fm-p%2F1435023%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FSAI1-MCLK1-source-select%2Fm-p%2F1435023%3C%2FA%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%A0%B7%E6%88%91%E5%B0%B1%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%90%8C%E4%B8%80%E5%BC%95%E8%84%9A%E7%94%A8%E4%BD%9C%20MCLK%20%E8%BE%93%E5%85%A5%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E6%9B%B4%E6%94%B9%E8%BF%99%E4%BA%9B%E5%AF%84%E5%AD%98%E5%99%A8%E5%AD%97%E6%AE%B5%EF%BC%88RM%20%E7%AC%AC%20326-327%20%E9%A1%B5%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CP%3E-%20IOMUXC_GPR_GPR1%20%E4%B8%AD%E7%9A%84%20SAI1_MCLK1_SEL%20-%20%E4%BB%8E%20000%20%E6%94%B9%E4%B8%BA%20011%EF%BC%8C%E4%BB%A5%E9%80%89%E6%8B%A9%20MCLK%20%E5%BC%95%E8%84%9A%3C%2FP%3E%3CP%3E-%20IOMUXC_GPR_GPR1%20%E4%B8%AD%E7%9A%84%20SAI1_MCLK1_DIR%20-%20%E5%B0%86%201%20%E6%94%B9%E4%B8%BA%200%EF%BC%8C%E4%BB%A5%E9%80%89%E6%8B%A9%20MCLK%20%E4%BD%9C%E4%B8%BA%E8%BE%93%E5%85%A5%E7%AB%AF%3C%2FP%3E%3CP%3E%E5%9C%A8%E8%BF%99%E4%B8%A4%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8CIOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_09%20%E9%83%BD%E8%AE%BE%E7%BD%AE%E4%B8%BA%203%EF%BC%8C%E5%B0%86%20AD_B1_09%20%E9%80%89%E6%8B%A9%E4%B8%BA%20MCLK%20%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E8%BF%99%E6%A0%B7%E5%81%9A%E5%B9%B6%E5%90%91%20J23%20%E7%9A%84%E5%BC%95%E8%84%9A%201%20%E6%8F%90%E4%BE%9B%E5%A4%96%E9%83%A8%E6%97%B6%E9%92%9F%E4%BF%A1%E5%8F%B7%E6%97%B6%EF%BC%8C%E5%8D%B4%E7%9C%8B%E4%B8%8D%E5%88%B0%20I2S%20%E8%BE%93%E5%87%BA%20-%20%E6%B2%A1%E6%9C%89%20BCLK%20%E7%94%9F%E6%88%90%E7%AD%89%E3%80%82%3C%2FP%3E%3CP%3E%E9%80%89%E6%8B%A9%20MCLK%20%E4%BD%9C%E4%B8%BA%20I2S%20%E4%B8%BB%E7%AB%99%E4%BC%A0%E8%BE%93%E7%9A%84%E8%BE%93%E5%85%A5%E6%98%AF%E5%90%A6%E8%BF%98%E9%9C%80%E8%A6%81%E6%9B%B4%E6%94%B9%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2370370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1062%20SAI%20MCLK%20input%20as%20master%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2370370%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262883%22%20target%3D%22_blank%22%3E%40mojolabs%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B7%B2%E5%9C%A8%E6%82%A8%E6%9C%80%E6%96%B0%E5%8F%91%E5%B8%83%E7%9A%84%E5%B8%96%E5%AD%90%E4%B8%AD%E6%8F%90%E4%BE%9B%E4%BA%86%E7%AD%94%E6%A1%88%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-RT-Crossover-MCUs%2FRT1062-SAI-MCLK-input-as-master%2Ftd-p%2F2369672%23%22%20target%3D%22_blank%22%3ERT1062%20SAI%20MCLK%20%E4%BD%9C%E4%B8%BA%E4%B8%BB%E6%8E%A7%E8%BE%93%E5%85%A5%20-%20NXP%20%E7%A4%BE%E5%8C%BA%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E9%9C%80%E8%A6%81%EF%BC%8C%E6%88%91%E4%BC%9A%E7%BB%A7%E7%BB%AD%E6%94%AF%E6%8C%81%E4%BD%A0%E7%9A%84%E5%B7%A5%E4%BD%9C%EF%BC%81%3C%2FP%3E%0A%3CP%3EBR%2C%3CBR%20%2F%3EEdwin.%3C%2FP%3E%3C%2FLINGO-BODY%3E
