Hi all,
I have a problem about giga lan ksz9021RN with i.mx6 Quad platform.
When I test the LAN speed, there have speed problem
If I connected to 100M hub, the LAN speed can reach up to 80Mbits/sec.
But if I connected to 1G hub, the LAN speed down speed to 10Mbits/sec.
Please refer the following pictures.
Could anyone can give me how to solve the problem? Thank for your help!!
Connected to 100M hub:
Connected to 1G Hub:
Solved! Go to Solution.
giga uses 4 pairs of lines, 100M uses 2 pairs of lines.
just want to make sure no connection issue and configuration issue.
E
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
Edwin
Had your issue got resolved? If yes, we are going to close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
