Programming i.MX RT1170 using MCUxpresso?
已解决
跳至解决方案
2,818 次查看
simmania
Can software for both the M4 and M7 cores of a i.MX RT1170 be developped using the MCUxpresso IDE?
标签 (1)
1 解答
2,792 次查看
kerryzhou
Hi @simmania ,
  Yes, of course, you can use the mcuxpresso to program both the CM7 and cm4 on RT1170.
  Please download the RT1170 SDK:
https://mcuxpresso.nxp.com/zh/builder?hw=MIMXRT1170-EVK
Then you can find the document:
SDK_2_13_10_MIMXRT1170-EVK\docs\Getting Started with MCUXpresso SDK for MIMXRT1170-EVK.pdf
Please refer to chapter 3.4 Build a multicore example application
Then you will know how to run both CM7 and CM4 core.
Wish it helps you!
Kerry
在原帖中查看解决方案
1 回复
2,793 次查看
kerryzhou
Hi @simmania ,
Wish it helps you!
Kerry
