Program PF0100 fuses in System
ソリューションへジャンプ
1,911件の閲覧回数
TerryMcHenry
I would like to program some of the fuses in the PF0100 PMIC after board assembly (i.MX6 design).  I assume I can do this using I2C?  How do I go about this using Linux?
ラベル(2)
1,708件の閲覧回数
weidong_sun
Hello, Terry,
     You can't program PF0100 fuse in linux, you only program it via OTG method. More detaild information, you can read document "MMPF0100 OTP Programming Instructions(AN4536)": MMPF0100: 14 Channel Configurable Power Management Integrated Circuit
Weidong
1,709件の閲覧回数
weidong_sun
Hello, Terry,
Weidong
