Problems setting eclipse for imx6ul
1,253件の閲覧回数
alexishernandez
Hi, i followed the steps in
Setting up the Eclipse IDE for Yocto Application Development
but i'm stuck at the "Reconfigure Project" step, i got this output when make this156096_156096.pngScreenshot from 2016-07-20 07_55_33.png
I chmod the workspace file to have 'rwx' permissions also i got the 2.1 yocto plugin version and the toolchain that i'm using is the corresponding to the image target (at least is what i think)156097_156097.pngScreenshot from 2016-07-20 08_07_14.png
Toolchain:core-image-sato-armv7a http://downloads.yoctoproject.org/releases/yocto/yocto-2.1/toolchain/i686/
Image: bitbake core-image-sato
Machine: imx6ulevk
Really need help with this one, thanks and regards
ラベル(2)
931件の閲覧回数
alexishernandez
Hi weidong.sun
     Thanks for your answer, the issue seems to be a mismatch between the sdk toolchain and the sysroot file, this can be solved by building your own sdk toolchain (see Appendix A.2 from sdk manual).
Hope someone find this thread helpful.
2 返答(返信)
931件の閲覧回数
weidong_sun
Hello Alexis,
   Ecllipse IDE is not our product, so it is not in the scope of support, but according to above log, I can give you some advice.
From No.1 screenshot, It seems that Makefile file should be needed for your application, so "no rule to make target" was reminded.
For more detailed about Ecllipse on how to create a Makefile, see here:
Help - Eclipse Platform
Hope above information can help you!
Weidong
932件の閲覧回数
alexishernandez
Hi weidong.sun
