Problem with the network manager
2,104件の閲覧回数
rajspatel1297
I'm just wondering that why in the boot sequence, there are two services with NetworkManager named with LSB.
Starting Network Manager...
Starting LSB: network connection manager...
[ OK ] Started Login Service.
[ OK ] Started Network Manager.
[ OK ] Started LSB: network connection manager.
[ OK ] Reached target Network.
Moreover the output of the systemctl --type=service contains two network manager services
network-manager.service loaded active exited LSB: network connection manager
NetworkManager-wait-online.service loaded active exited Network Manager Wait Online
NetworkManager.service loaded active running Network Manager
Can someone please explain it?
3 返答(返信)
2,094件の閲覧回数
jimmychan
Which board are you using?
Which version of BSP are you using?
2,090件の閲覧回数
rajspatel1297
I’m using compulab cl-som-imx7 board with Dunfell version.
https://github.com/compulab-yokneam/compulab-fslc-bsp/tree/dunfell
2,085件の閲覧回数
jimmychan
In our BSP, we don't have this network manager. As the BSP package is board specific, you may contact the support of Compulab for this network manager issues.
