Problem with menuconfig
rkp
I am trying to build Android 4.4.2 kitkat. I have done some optimization in kernel by configuring it using make menuconfig. The problem is when I am building the kernel with new configuration, menuconfig changes not taking effect.
I have done the following changes in kernel:
    1. Prompt for development and/or incomplete code/drivers -  Disabled
    2. Optimize for size  -   Enabled
    3. Profiling support -  Disabled
    4. Enable support for printk  -  Disabled
    5. BUG() support -  Disabled
    6. Enable ELF core dumps -  Disabled
    7. Suspend to RAM and standby  -  Disabled
    8. Power Management Debug Support -   Disabled
    9. Kernel Debugging -  Disabled
    10. Enable Verbose -   Disabled
    11. Early Printk  -  Disabled
    12. Tracers -   Disabled
    13. Kernel Compression Mode - LZO  ...
please help me to solve this
Thanks & Regards,
Roopesh
Labels (3)
saurabh206
Senior Contributor III
Hi Roopesh
You can try following steps.
If you are using imx6_android_defconfig than copy it to .config
export ARCH=arm
make menuconfig
make uImage
Saurabh
