Problem with galcore on imx6solosabre
3,101件の閲覧回数
alexberenshtein
Hi. Thank for replay.
I tested 2 EVB , with CPU - imx6dl & imx6dlsolo ( EVB - imx6dlsabresd & imx6solosabresd ) , as you wrote Yocto - 4.9.88 (ROCKO).
EVB imx6dlsabresd - works great with Xorg , with QT5 , with galcore.
But EVB imx6solosabresd - It remained the same problem , galcore do no working !!!
I use the same Image - U-Boot , Kernel, FS …..
Please help.
I need on upgrade Software , from 4.1.15 to 4.9.88 / 4.14.XX.
Best regards.
ラベル(2)
タグ(1)
4 返答(返信)
2,891件の閲覧回数
joanxie
we have already escalate your question to internal expert team, any update, you will get mail about this issue
2,890件の閲覧回数
alexberenshtein
Hi.
I forgot to say - only galcore  do not working.
I do not see  "/dev /galcore".
Best regards.
2,890件の閲覧回数
alexberenshtein
Hi.
We have Freescale boards.
Board with i.mx6dl-sabresd  & board i.mx6solo-sabresd . This is same boards. Only CPU others.
i.mx6 Dual light (CPU) & i.mx6 Solo (CPU)
Best regards.
2,890件の閲覧回数
joanxie
what boards do you have? nxp board or the third party board? as I known we only have imx6dl sdp board, for imx6s board, you can download image and boot up successfully, just couldn't use galcore ?
