Problem with MFGTool2
marcelballmann
I have a SABRE-SD board with a iMX6Q. I have connect the USB port OTG and have done the changes from the chapter 3.3 of the Android Quick Start Guide, Rev jb4.2.2_1.0.0-GA, 05/2013.
But when I want to start the exe at point 7 of the Guide, I get a error message and no MfgTool opens. And the messages in the log do not help me, maybe you. The log file you can find attached. Thank you....
Original Attachment has been moved to: MfgTool.log.zip
Labels (3)
jam
Change the name of the u-boot file that the instructions tell you to use to "u-boot."
SergioSolis
Hello Marcel,
Did you try to open MFGTool before you did changes to the files?, what changes did you do to UCL2.xml?
