Problem in imx-android-13.4.1.04
alex_park
I don't know if this matter is related to porting issue or my misusing of android,
when I use SufaceView and TextView in the same RelativeLayout,
it shows like below, ( * "0" char is surrounded by some transparent rectangle..)
If I use other view instead of "SurfaceView", then it's fine.
can you figure out what this problem is ?
Thanks in advance.
Plus, I checked this with Eclipse DDMS, but it looks perfectly fine..
Left one is normal(DDMS capture), right one is on the board(abnormal).
** added comment (2013/10/28)
   I deployed same APK in LG G2 Phone, and everything seems fine.
   Definitely, mx6 board seems to have some problem..
MINKYU PARK 님이 메시지를 편집했습니다.
Labels (4)
YixingKong
Senior Contributor IV
Minkyu
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
YixingKong
Minkyu
We have not got your response yet and will close the discussion in 3 days. If you still need help, please feel free to reply with an update to this discussion.
Yixing
YixingKong
Minkyu
We are sorry for getting back to you so late. Are you still stuck with the issue? If you have somehow to resolved the
issue, can we close the discussion? If you still need help, please feel free to reply with an update to this discussion.
Yixing
