Problem import project fro imx93 evk
1,319 次查看
geb
I have a problem to import e project that we have modified that is the hello world for use it for try to change color to the rgb pwm led but when I try to import it says invalid CMake project archive, there is the possibility to resolve this problem?
4 回复数
1,260 次查看
geb
Hi @Chavira ,
The external project is imported now, but it's say that can't debug because can't crate a cmake build why?
1,296 次查看
geb
Hi @Chavira ,
I'm using MCUXPRESSO extention to import a project, but not from the demo, I have imported a project that we have modified but when I try to debug it says that cn't debug because can't crate a cmake build why?
Thank & Regards
1,287 次查看
Chavira
Hi @geb!
You can import a local project too.
I have tried without problems.
You have to select the toolchain and the sdk path.
1,308 次查看
Chavira
Hi @geb!
Thank you for contacting NXP Support!
You should use the MCUXPRESSO extention to import a project:
Best Regards!
Chavira
