Power supply for iMX95 FRDM kit
1,004件の閲覧回数
Harish_V
I am going through the getting started and cannot find anywhere mentioning the voltage rating. Can we use the 12V supply provided for iMX95 Verdin EVK for the FRDM. Only a C to C cable has been provided and no other power supply is provided with the kit.
Kindly let me know if anyone is working with the FRDM kit
5 返答(返信)
993件の閲覧回数
yipingwang
No — you should NOT use a 12 V power supply on the FRDM‑i.MX95 board.
The FRDM‑i.MX95 is designed to be powered via USB Type‑C with USB‑PD, not a fixed 12 V DC input.
978件の閲覧回数
Harish_V
Can you please specify the power rating of the PD used. Is it 12V ? Can you please verify and let us know. Thanks
971件の閲覧回数
yipingwang
There is NO fixed 12 V requirement specified
The only requirement is:
  • Use a USB‑PD adapter ≥ 65 W
950件の閲覧回数
Harish_V
Thank you for your reply. I am able to power it on.
Also for serial console setup only the CH343USB works ? The picocom will not work similar to IMX95 EVK.
948件の閲覧回数
yipingwang
The FRDM‑i.MX95 board uses a CH344 USB‑to‑UART bridge, not an FTDI device like the i.MX95 EVK.
You can use standard terminal tools such as picocom, minicom, or screen. There is no restriction to a specific “CH343 tool”.
If picocom does not work, the issue is usually related to: - selecting the correct /dev/ttyUSBx port (the CH344 exposes multiple UARTs), or - missing or incompatible CH34x driver on the host. The serial console configuration is standard (115200-8N1).
%3CLINGO-SUB%20id%3D%22lingo-sub-2378110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX95%20FRDM%E3%82%AD%E3%83%83%E3%83%88%E7%94%A8%E9%9B%BB%E6%BA%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%85%A5%E9%96%80%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E8%AA%AD%E3%82%93%E3%81%A7%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E9%9B%BB%E5%9C%A7%E5%AE%9A%E6%A0%BC%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E7%AE%87%E6%89%80%E3%81%8C%E8%A6%8B%E5%BD%93%E3%81%9F%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82iMX95%20Verdin%20EVK%E3%81%AB%E4%BB%98%E5%B1%9E%E3%81%AE12V%E9%9B%BB%E6%BA%90%E3%82%92FRDM%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%82%AD%E3%83%83%E3%83%88%E3%81%AB%E3%81%AFC%20to%20C%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%AE%E3%81%BF%E3%81%8C%E4%BB%98%E5%B1%9E%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%9D%E3%81%AE%E4%BB%96%E3%81%AE%E9%9B%BB%E6%BA%90%E3%81%AF%E4%BB%98%E5%B1%9E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3EFRDM%E3%82%AD%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E6%96%B9%E3%81%8C%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%82%89%E3%80%81%E3%81%9C%E3%81%B2%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2378730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Power%20supply%20for%20iMX95%20FRDM%20kit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3EFRDM-i.MX95%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81i.MX95%20EVK%E3%81%AE%E3%82%88%E3%81%86%E3%81%AAFTDI%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81CH344%20USB-to-UART%E3%83%96%E3%83%AA%E3%83%83%E3%82%B8%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3Epicocom%E3%80%81minicom%E3%80%81screen%E3%81%AA%E3%81%A9%E3%81%AE%E6%A8%99%E6%BA%96%E7%9A%84%E3%81%AA%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E7%89%B9%E5%AE%9A%E3%81%AE%E3%80%8CCH343%E3%83%84%E3%83%BC%E3%83%AB%E3%80%8D%E3%81%AB%E9%99%90%E5%AE%9A%E3%81%95%E3%82%8C%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3Epicocom%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E9%80%9A%E5%B8%B8%E3%80%81%E6%AC%A1%E3%81%AE%E3%81%84%E3%81%9A%E3%82%8C%E3%81%8B%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82-%20%E6%AD%A3%E3%81%97%E3%81%84%2Fdev%2FttyUSBx%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%EF%BC%88CH344%E3%81%AF%E8%A4%87%E6%95%B0%E3%81%AEUARTs%E3%82%92%E5%85%AC%E9%96%8B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%89%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%20-%20%E3%83%9B%E3%82%B9%E3%83%88%E3%81%ABCH34x%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E3%81%AA%E3%81%84%E3%81%8B%E3%80%81%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%8C%E3%81%AA%E3%81%84%E3%80%82%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AE%E6%A7%8B%E6%88%90%E3%81%AF%E6%A8%99%E6%BA%96%EF%BC%88115200-8N1%EF%BC%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2378724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Power%20supply%20for%20iMX95%20FRDM%20kit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%AF%E3%80%81CH343USB%E3%81%AE%E3%81%BF%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9Fpicocom%E3%81%AFIMX95%20EVK%E3%81%A8%E5%90%8C%E3%81%98%E3%82%88%E3%81%86%E3%81%AB%E3%81%AF%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2378218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Power%20supply%20for%20iMX95%20FRDM%20kit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E12V%E3%81%AE%E5%9B%BA%E5%AE%9A%E8%A6%81%E4%BB%B6%E3%81%AF%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%0A%3CP%3E%E5%94%AF%E4%B8%80%E3%81%AE%E6%9D%A1%E4%BB%B6%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E65W%E4%BB%A5%E4%B8%8A%E3%81%AEUSB-PD%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2378191%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Power%20supply%20for%20iMX95%20FRDM%20kit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378191%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BPD%EF%BC%88%E3%83%95%E3%82%A9%E3%83%88%E3%83%80%E3%82%A4%E3%82%AA%E3%83%BC%E3%83%89%EF%BC%89%E3%81%AE%E5%AE%9A%E6%A0%BC%E9%9B%BB%E5%8A%9B%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F12V%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%AE%E4%B8%8A%E3%80%81%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2378126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Power%20supply%20for%20iMX95%20FRDM%20kit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E%E3%81%84%E3%81%84%E3%81%88%E3%80%81%3C%2FSTRONG%3E%20%3CSTRONG%3EFRDM-i.MX95%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF12V%E9%9B%BB%E6%BA%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSTRONG%3E%3CBR%20%2F%3EFRDM-i.MX95%E3%81%AF%E3%80%81%E5%9B%BA%E5%AE%9A%E3%81%AE12V%20DC%E5%85%A5%E5%8A%9B%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%20%3CSTRONG%3EUSB-PD%E5%AF%BE%E5%BF%9C%E3%81%AEUSB%20Type-C%3C%2FSTRONG%3E%E7%B5%8C%E7%94%B1%E3%81%A7%E7%B5%A6%E9%9B%BB%E3%81%95%E3%82%8C%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
