Power supply for iMX95 FRDM kit
Harish_V
I am going through the getting started and cannot find anywhere mentioning the voltage rating. Can we use the 12V supply provided for iMX95 Verdin EVK for the FRDM. Only a C to C cable has been provided and no other power supply is provided with the kit.
Kindly let me know if anyone is working with the FRDM kit
yipingwang
No — you should NOT use a 12 V power supply on the FRDM‑i.MX95 board.
The FRDM‑i.MX95 is designed to be powered via USB Type‑C with USB‑PD, not a fixed 12 V DC input.
Harish_V
Can you please specify the power rating of the PD used. Is it 12V ? Can you please verify and let us know. Thanks
yipingwang
There is NO fixed 12 V requirement specified
The only requirement is:
  • Use a USB‑PD adapter ≥ 65 W
Harish_V
Thank you for your reply. I am able to power it on.
Also for serial console setup only the CH343USB works ? The picocom will not work similar to IMX95 EVK.
yipingwang
The FRDM‑i.MX95 board uses a CH344 USB‑to‑UART bridge, not an FTDI device like the i.MX95 EVK.
You can use standard terminal tools such as picocom, minicom, or screen. There is no restriction to a specific “CH343 tool”.
If picocom does not work, the issue is usually related to: - selecting the correct /dev/ttyUSBx port (the CH344 exposes multiple UARTs), or - missing or incompatible CH34x driver on the host. The serial console configuration is standard (115200-8N1).
%3CLINGO-SUB%20id%3D%22lingo-sub-2378110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPower%20supply%20for%20iMX95%20FRDM%20kit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20going%20through%20the%20getting%20started%20and%20cannot%20find%20anywhere%20mentioning%20the%20voltage%20rating.%20Can%20we%20use%20the%2012V%20supply%20provided%20for%20iMX95%20Verdin%20EVK%20for%20the%20FRDM.%20Only%20a%20C%20to%20C%20cable%20has%20been%20provided%20and%20no%20other%20power%20supply%20is%20provided%20with%20the%20kit.%26nbsp%3B%3CBR%20%2F%3EKindly%20let%20me%20know%20if%20anyone%20is%20working%20with%20the%20FRDM%20kit%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2378730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Power%20supply%20for%20iMX95%20FRDM%20kit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3EThe%20FRDM%E2%80%91i.MX95%20board%20uses%20a%20CH344%20USB%E2%80%91to%E2%80%91UART%20bridge%2C%20not%20an%20FTDI%20device%20like%20the%20i.MX95%20EVK.%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3EYou%20can%20use%20standard%20terminal%20tools%20such%20as%20picocom%2C%20minicom%2C%20or%20screen.%20There%20is%20no%20restriction%20to%20a%20specific%20%E2%80%9CCH343%20tool%E2%80%9D.%3C%2FDIV%3E%0A%3CDIV%3EIf%20picocom%20does%20not%20work%2C%20the%20issue%20is%20usually%20related%20to%3A%20-%20selecting%20the%20correct%20%2Fdev%2FttyUSBx%20port%20(the%20CH344%20exposes%20multiple%20UARTs)%2C%20or%20-%20missing%20or%20incompatible%20CH34x%20driver%20on%20the%20host.%20The%20serial%20console%20configuration%20is%20standard%20(115200-8N1).%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2378724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Power%20supply%20for%20iMX95%20FRDM%20kit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378724%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20your%20reply.%20I%20am%20able%20to%20power%20it%20on.%26nbsp%3B%3CBR%20%2F%3EAlso%20for%20serial%20console%20setup%20only%20the%20CH343USB%20works%20%3F%20The%20picocom%20will%20not%20work%20similar%20to%20IMX95%20EVK.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2378218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Power%20supply%20for%20iMX95%20FRDM%20kit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThere%20is%20NO%20fixed%2012%E2%80%AFV%20requirement%20specified%3C%2FP%3E%0A%3CP%3EThe%20only%20requirement%20is%3A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EUse%20a%20USB%E2%80%91PD%20adapter%20%E2%89%A5%2065%E2%80%AFW%3C%2FLI%3E%0A%3C%2FUL%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2378191%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Power%20supply%20for%20iMX95%20FRDM%20kit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378191%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ECan%20you%20please%20specify%20the%20power%20rating%20of%20the%20PD%20used.%20Is%20it%2012V%20%3F%20Can%20you%20please%20verify%20and%20let%20us%20know.%20Thanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2378126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Power%20supply%20for%20iMX95%20FRDM%20kit%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3ENo%20%E2%80%94%20you%20should%20NOT%20use%20a%2012%3C%2FSTRONG%3E%3CSTRONG%3E%E2%80%AFV%20power%20supply%20on%20the%20FRDM%E2%80%91i.MX95%20board.%3C%2FSTRONG%3E%3CBR%20%2F%3EThe%20FRDM%E2%80%91i.MX95%20is%20designed%20to%20be%20powered%20via%20%3CSTRONG%3EUSB%20Type%E2%80%91C%20with%20USB%E2%80%91PD%3C%2FSTRONG%3E%2C%20not%20a%20fixed%2012%E2%80%AFV%20DC%20input.%3C%2FP%3E%3C%2FLINGO-BODY%3E
