Power button in Android
hajimohammed
      We are currently working on IMX6 custom board & our OS is android lollipop with 3.10.53 linux kernel. When we press the power button, we have to get Reboot / Shutdown  power status popup but we are not able to configure our gpio to perform this power button functionality.
       Please provide a solution to fix it
Haji
aravinthkumarja
Senior Contributor II
Hi Haji,
In dts under gpio-keys section add the below line.
power {
label = "Power Button";
gpios = <&gpio3 29 1>;   //Here you need to give your gpio number
gpio-key,wakeup;
linux,code = <KEY_POWER>;
Hope above information is helpful for you!
Aravinth
hajimohammed
  When we using below code,we are able to get only power off popup (working). If i want to reboot/restart popup what are the changes i need to do
#define POWER_OFF        IMX_GPIO_NR(2, 4)
static struct gpio_keys_button buttons[] = {
                .gpio           = POWER_OFF,
                .code           = KEY_POWER,
                .desc           = "Power Off Button",
                .type           = EV_KEY,
                .active_low     = 0,
                .wakeup         = 1,
static struct gpio_keys_platform_data button_data = {
        .buttons        = buttons,
        .nbuttons       = ARRAY_SIZE(buttons),
static struct platform_device button_device = {
        .name           = "gpio-keys",
        .id             = -1,
        .num_resources  = 0,
        .dev            = {
                .platform_data  = &button_data,
vinodmaverickr0
Hi Haji,
For restart you can try by modifying the below code.
.code           = KEY_POWER,
.code        =  KEY_RESTART,  //try this
Vinod
aravinthkumarja
Hi Haji,
Do the below changes,
.code = KEY_SCREENLOCK,
Aravinth
hajimohammed
Hi aravinthkumar,
         With below code changes also we are getting only poweroff popup. but we need reboot/restart popup
aravinthkumarja
Hi Haji,
That is application layer dependency. Ask them to check, If you get long press event from "KEY_SCREENLOCK" , popup the expected function(Reboot, poweroff, Screenshot, etc).
Aravinth
deepanrajanbara
hi aravinthkumar jayaprakasam
Is there any way to configure the same power button click event to show reboot option also ?
Thank you,
Deepanraj.A
aravinthkumarja
Hi Deepanraj,
Yes. we can do it. It's just android pop-up.
Aravinth
deepanrajanbara
How to configure that pop up do you know ?
Thank you,
Deepanraj.A
aravinthkumarja
Hi Deepanraj,
Sorry for the delay. Android App developer know about it.
Aravinth
Bio_TICFSL
Hi haji,
You need to do a key mapping to the AOSP power key
PowerManager | Android Developers
Key layout files are searched for in the following order:
  • /system/usr/keylayout/Vendor_XXXX_Product_XXXX_Version_XXXX.kl
  • /system/usr/keylayout/Vendor_XXXX_Product_XXXX.kl
  • /system/usr/keylayout/DEVICE_NAME.kl
  • /data/system/devices/keylayout/Vendor_XXXX_Product_XXXX_Version_XXXX.kl
  • /data/system/devices/keylayout/Vendor_XXXX_Product_XXXX.kl
  • /data/system/devices/keylayout/DEVICE_NAME.kl
  • /system/usr/keylayout/Generic.kl/
