Porting driver
Porting driver
5,502 次查看
phamhuynh
good day for everybody, i'm porting driver for display of Mirasol, i use iMX6SL EVK, and display:
- Module display Mirasol Chocolate RGB 1.5" 288x192
- Driver IC Display: PA6561A2
- Interface: MIPI DBI 8 bit parrallel, 3/4-wire SPI.
Who have driver for this display, or have ported driver for this display?? can help me for driver, i need driver for this module display
thank for view!
标签 (2)
5,093 次查看
Yuri
may be manufacturer can provide a Linux driver ?
~Yuri.
7 回复数
5,093 次查看
Yuri
Please use the recent (Yocto) Linux BSP for the i.MX6 EVK.
Summary Page :
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=IMX6_SW
The most simple way to start - to use demo image :
$ sudo dd if= fsl-image-x11-imx6slevk.sdcard of=/dev/sdb bs=1M
Please look at the following for some details.
"Task #4 - Deploy and test"
https://community.freescale.com/docs/DOC-94989
Next, You may refer to Chapter 7 (MIPI DSI Driver) of “i.MX_6_Linux_Reference_Manual.pdf”
from the package documentation and use this driver as base for own design.
Yuri
5,093 次查看
phamhuynh
hi Yuri, i saw your direction and do following, but i find not thing about driver for ic display :smileysad:
5,093 次查看
Yuri
I meant using Freescale (MIPI DSI) driver only as base for further
development , assuming changing and debugging driver codes.
~Yuri.
5,093 次查看
phamhuynh
hi, have you porting guide driver for display??
5,093 次查看
Yuri
I am afraid we do not have detailed guide for display driver porting, sorry.
The Yocto "i.MX_6_BSP_Porting_Guide.pdf" contains only Chapter 6
(Connecting an LVDS Panel to an i.MX 6Dual/6Quad/6Solo/6DualLite
Reference Board).
~Yuri.
5,093 次查看
phamhuynh
i'm using mirasol diplay, i have porting driver for module display, i know that, i'll config pad, GPIO, interface..., i get it, but, i can't write driver for ic display PA6561A2, i;m searching it!
5,094 次查看
Yuri
~Yuri.
