Plug & Trust MW SD Card Image SE050+IMX6UL source code
1,651件の閲覧回数
wangxuehua
Hello, Could you tell me where can I get the source code of imx-4.14.98-2.0.0-02.12.00.img which is download from https://www.nxp.com/products/security-and-authentication/authentication/edgelock-se050-plug-trust-se...  —— Tools and Software——Plug & Trust MW SD Card Image?
タグ(1)
1,645件の閲覧回数
jimmychan
The source code of the kernel can be get from the BSP build. We use Yocto to build the BSP.
You can get the documentation from here.
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
Then follow the i.MX_Yocto_Project_User's_Guide.pdf to build the BSP. After built successfully, the source code can be found in the <yocto_folder>/<build_folder>/tmp/work/<board_folder>/linux-imx
And here is the web page version for the kernel source code
https://source.codeaurora.org/external/imx/linux-imx/tree/?h=imx_4.14.98_2.0.0_ga
