In the tool "Pins for i.MX Version 2.0" for MCIMX7DxxVM and MCIMX7SxxVM, the following pins are not matched with datasheet.
Ball Name: DRAM_CAS_B
datasheet : pin AC14
Tool: pin AD17
Ball Name: DRAM_DQM1
datasheet: pin pin AD17
Tool: pin AC14
Could you please confirm that this is just the tool issue, not the datasheet?
Thank you and wait for your feedback.
Solved! Go to Solution.
Hello
The values in the Datasheet are correct.
The ticket for Pins Tool correction has been already submitted.
Yuri
Hello
Yuri
