Pinmux modification at runtime
ソリューションへジャンプ
3,666件の閲覧回数
JeromeBaron
Hi everyone,
I'm working on a platform with a iMX28 that runs Linux. I would like to know if it's allowed to change the pinmux at runtime, while in the Linux.
My goal is to use a SPI port, program a device, then change those IO to GPIO after the programmation.
Can I do this? How?
Jerome
3,265件の閲覧回数
JeromeBaron
It appears the answer is a simple memory write to the CPU registers. I have found a small application(imxregs) in amadeus distribution to access those registers.
2 返答(返信)
3,265件の閲覧回数
JeromeBaron
3,265件の閲覧回数
Hi Jerome
seems not, since linux spi driver will own pins. To rmmod driver one needs
to be administrator with root permissions.
