Parallel Camera Interface
jacquesdumarest
I would like to use the parallel camera interface in YUV mode on the i.MX6Q. How should I connect Y and UV (16 bit I/F), and what is the mux timing?  Is this YUV 16 bit input mode supported in Linux package? Android package?   Any documentation on this subject is welcome.   Thank you very much,   Jacques
Labels (3)
Rita_Wang
Hi Jacques
You can go to http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=i.MX6Q&nodeId=018rH3ZrDRB24A&fpsp=1&t... to download the reference manual of i.MX6Q.
Best Regards
Dan
