PPS signal
PPS signal
AsBo
I'm working with the EVKB-IMXRT1050 board. I'm developing an time synchronization application with gPTP and I'm basing my development on this examples with FreeRTOS: https://www.nxp.com/design/software/development-software/mcuxpresso-software-and-tools-/wired-commun...
I want to use the PPS signal to see the accuracy of the synchronization, but unfortunately, the example running in the EVKB-IMXRT1050 board, doesn't generate PPS signal and I'm having problems on generating it.
Is there any documentation about it? Or can anyone explain the steps to follow?
Thank you very much.
