PING COMMAND IN U-BOOT
5,225 次查看
saida
hi
ping command is working in sabre SD board ("Host is alive")(ping command from u-boot prompt)
but not working on my custom board
i am using same phy(AR8031) as in sabresd board,there is no change in hardware with respect to sabre board.
when i am doing ping command from u-boot prompt it not working and results "host is not alive"
what could be the problem ?
the recommendations are highly appreciated
thanks and regards
Saida
标签 (1)
4 回复数
4,830 次查看
joanxie
could you share the log file? could you get ethernet information in the uboot, when you ping, what message do you get?
4,830 次查看
saida
hi
thanks for your reply
i am getting "ARP Retry count exceeded; starting again" message in u-boot
and  i am running tcpdump also where i am getting following message
" who has 10.0.0.6 tell to 10.0.0.8"
" 10.0.0.6 is at this MAC address "
i am thinking that message is transmitting properly but reception is not happening
plz help
regards
saida
4,830 次查看
joanxie
what source code in the uboot do you change? since you don't change any hardware, it should be the same settings, did you set correct MAC address in the uboot? pls send the log file first
4,830 次查看
joanxie
could you share the log file ? in the uboot, can you get the ethernet correctly?
