PF8100EPES EQES OTP issues
Sam1978
hi folks:
 I applied PF8100EPES and PF8100EQES for imx8qm6avufabb,also i setup a configure script for OTP burnning as per otp form in directory flexGUI,i tried to run this script to burn otp fuse with KITPF8200FRDMPGM tools,but it always restore to default value after re-power on ,anybody can give me your solutions if you met this issue ,thanks!
 best reguards
 Sam
disconnect usb cable,and power up again:
run read otp script,showed below:
Hi Sam
seems there is some misunderstanding as PF8100EPES and PF8100EQES are already
programmed parts and due to "OTP (One time programmable) memory for device configuration"
as described in p.9 below datasheet, their configuration can not be changed.
PF8100_PF8200, 12-channel power management integrated circuit for high performance applications - Da...
For OTP burnning it is necessary to use MC33PF8100A0ES (Not programmed) part as
described in Table 2. Ordering information.
