PCIE INTEGERATION WITH imx8mq
943件の閲覧回数
ShivaniS
Hi Team,
We need your support to enable and make SM768 will work with imx8mq linux board.
I will give small brief about the our setup & use cases and queries.
We are using Nitrogen8m SOM carrier board and SM768 eval kit for establish the PCIe to HDMI output feature.
So far we are trying to make SM768 Eval kit independently, it will display the HDMI output  in windows laptop with USB3.0 interface, but unfortunately we couldn't achieve the same.
Currently we are planning to connect the SM768 Eval kit to Nitrogen8m Carrier board (What we are using) and we are going to enable the SM768 driver for the same in the imx8mq .dts file & kernel.
We could not find much information about the SM768 based device tree configuration details and drivers for imx8mq via yocto based environment.
So, I would request you to please provide the configuration & driver details for imx8mq processor and please do the needful.
Thanks and Regards,
Shivani S
0 返答(返信)
