Ov5645 Probing failed
2,679 次查看
santhanakumars
    I need to port Omni vision ov5645 camera module in imx6qdl apalis ixora board for Android Nougat plaform, I added dts support in imx6 board & probing itself failed for me. Anyone suggest how to check it's hardware problem or any configuration missing. difference i found in ov5645 & ov5647 interfaced in my board, ov5645 chip address not found.
Camera Logs:
camera ov5645_mipi is not found
u-boot args:
In ov5647,
i2c probe
it showing valid chip address : 36
In ov5645,
i2c probe
标签 (2)
2,464 次查看
Bio_TICFSL
Hello Santhana,
You have to create your own driver for OV5645, the i.MX6 have the driver for OV5640 which should be similar to yours.
2,464 次查看
santhanakumars
Thanks for replying, I created own driver for ov5645,   if ov5645 probing in imx6 board,  & i checked with same i2c address for ov5640 & ov5645 in imx6 . So I removed dependencies on ov5640 in imx6 & again checking probe itself not working.
What issues for ov5645 probing in imx6 board ? Is it any hardware work or need some changes in i2c address for ov5645?
SanthanaKumarS
2,464 次查看
vinothkumars
Senior Contributor IV
Santhanam,
Please check this link, it will help you,
https://community.nxp.com/docs/DOC-106436
VonothS
Vinothkumar Sekar
