Ov5645 Probing failed
santhanakumars
    I need to port Omni vision ov5645 camera module in imx6qdl apalis ixora board for Android Nougat plaform, I added dts support in imx6 board & probing itself failed for me. Anyone suggest how to check it's hardware problem or any configuration missing. difference i found in ov5645 & ov5647 interfaced in my board, ov5645 chip address not found.
Camera Logs:
camera ov5645_mipi is not found
u-boot args:
In ov5647,
i2c probe
it showing valid chip address : 36
In ov5645,
i2c probe
Labels (2)
Bio_TICFSL
Hello Santhana,
You have to create your own driver for OV5645, the i.MX6 have the driver for OV5640 which should be similar to yours.
santhanakumars
Thanks for replying, I created own driver for ov5645,   if ov5645 probing in imx6 board,  & i checked with same i2c address for ov5640 & ov5645 in imx6 . So I removed dependencies on ov5640 in imx6 & again checking probe itself not working.
What issues for ov5645 probing in imx6 board ? Is it any hardware work or need some changes in i2c address for ov5645?
SanthanaKumarS
vinothkumars
Senior Contributor IV
Santhanam,
Please check this link, it will help you,
https://community.nxp.com/docs/DOC-106436
VonothS
Vinothkumar Sekar
