OpenEmbedded and Angstrom for imx35
2,352 次查看
RTovo1z
Hi all.
I'm trying to use bitbake for building a filesystem for my imx35pdk.
The nearest official machine is mx31ads.
Is there someone working on a mx35pdk machine for openembedded or know the steps to adapt mx31ads machine target to mx35pdk?
Robson
标记 (1)
2,163 次查看
Prashanth_ng
Hi RTovo, Can you please tell the procedure or detail to build the BSP for imx35pdk. Aleast the basic steps to startup. It would be of great help.
2,163 次查看
RTovo1z
Thank you Marc, very much. As soon as I switch back to this task I'll give you a feedback. Looking forward to see OE working on my imx35 board.
2,163 次查看
MarcReilly
Hi, I started with this git branch which I found when I was starting. Some other things that might come in handy: (for version 2 of the PDK) UBOOT_ENTRYPOINT = "80008000" MKUBIFS_ARGS = "-m 2048 -e 252KiB -c 2047" UBINIZE_ARGS = "-m 2048 -p 256KiB" EXTRA_IMAGECMD_jffs2 = "--pagesize=0x800 --eraseblock=0x40000 --no-cleanmarkers --pad" Hope this helps, give me a yell if you get stuck. Cheers, Marc
