Open OCD Configuration for IMX8DXLEVK
ソリューションへジャンプ
3,515件の閲覧回数
chanks
The BCU documentation mentions that the imx8dxl can be debugged using OpenOCD.  However, in looking at the Open OCD repository, I can't find the appropriate config files for the IMX8DXL.  Do these files exist somewhere?  All I can see are the files for the IMX8M and the evaluation board for the IMX8M.
3,346件の閲覧回数
hector_delgado
Hi @chanks ,
Here's the missing file, sorry for any inconvenience this may have caused. Thank you.
Hector.
6 返答(返信)
3,453件の閲覧回数
hector_delgado
Hi @chanks ,
I hope you're doing well. Here are the configuration files for the IMX8DXL EVK. Let me know if this was of any help.
Hector.
3,441件の閲覧回数
chanks
It looks like this is two of the three needed files.  I'm still missing the imx8dxl-evk.cfg file that should go in the ftdi directory.
I think I have the second config file in this command, but not the first config file:
openocd -f tcl/interface/ftdi/imx8dxl-evk.cfg -f tcl/board/imx8dxl-evk.cfg
3,347件の閲覧回数
hector_delgado
Hi @chanks ,
Hector.
3,341件の閲覧回数
chanks
Thanks so much! With this file and the file above I can make a connection.
3,408件の閲覧回数
hector_delgado
Hi @chanks ,
Let me double check this. Thank you.
Hector.
3,486件の閲覧回数
hector_delgado
Hi @chanks ,
I hope you're doing great! I'm currently reviewing and double checking this information since there may be some inconsistencies with the support of OpenOCD for i.MX devices. I'll let you know as soon as I get more information from our team. Thank you!
Hector.
