OV5640 flash in Android
lwtimesys
We would like to use the strobe/flash function for the ov5640 camera with Android on the imx8mm board.
This is supported in Linux with a patch to add the v4l2 flash subdev: https://www.spinics.net/lists/linux-media/msg175171.html
However, the camera code in vendor/nxp-opensource/imx does not appear to query the flash subdevs. Is there an existing patch to enable this function?
Chavira
Hi @lwtimesys!
Thank you for contacting NXP Support!
The Documentation doesn't mention anything about that feature, but you can try to implement that feature on Android.
https://www.nxp.com/design/design-center/software/embedded-software/i-mx-software/android-os-for-i-m...
Sorry for the mistake!
Best Regards!
Chavira
