OPTEE Examples
OPTEE Examples
1,828件の閲覧回数
YY34173
I'm building an Yocto image using on a Var-som-mx8m-nano with Scarthgap. (https://dev.variscite.com/var-som-mx8m-nano/mx8mn-yocto-scarthgap-6.6.52_2.2.0-v1.1/yocto-build-rele...)
I've followed this guide: https://community.nxp.com/t5/i-MX-Processors/Building-optee-examples-and-trusted-Apps-in-Yocto-bitba...
Although this answer is old, I've added the Optee-examples version 4.7, and populated the .bb file with the information found in that link. The local.conf file I edited according to the official docs since the advice on the answer is depreciated.
However, the rest of the optee files are version 4.4. If I try to bitbake optee-examples without adding the .bb file, I get an error saying there's no target.
I ran bitbake -DDD optee-examples
I get the following error:
DEBUG: Attempting to disable network for do_install
DEBUG: SOURCE_DATE_EPOCH: 1627299039
DEBUG: Executing task do_install
DEBUG: optee-examples-4.7.0-r0 do_install: Executing python function extend_recipe_sysroot
DEBUG: optee-examples-4.7.0-r0 do_install: Python function extend_recipe_sysroot finished
DEBUG: optee-examples-4.7.0-r0 do_install: Executing shell function do_install
ERROR: optee-examples-4.7.0-r0 do_install: ExecutionError('/home/optee/var-fsl-yocto/build_xwayland/tmp/work/imx8mn_var_som-poky-linux/optee-examples/4.7.0/temp/run.do_install.53250', 1, None, None)
ERROR: Logfile of failure stored in: /home/optee/var-fsl-yocto/build_xwayland/tmp/work/imx8mn_var_som-poky-linux/optee-examples/4.7.0/temp/log.do_install.53250
Log data follows:
| DEBUG: Executing python function extend_recipe_sysroot
| NOTE: Direct dependencies are ['/home/optee/var-fsl-yocto/sources/meta-imx/meta-imx-bsp/recipes-security/optee/optee-client_4.4.0.imx.bb:do_populate_sysroot', '/home/optee/var-fsl-yocto/sources/meta-imx/meta-imx-bsp/recipes-security/optee/optee-os_4.4.0.imx.bb:do_populate_sysroot', '/home/optee/var-fsl-yocto/sources/poky/meta/recipes-core/glibc/glibc_2.39.bb:do_populate_sysroot', '/home/optee/var-fsl-yocto/sources/poky/meta/recipes-devtools/gcc/gcc-cross_13.3.bb:do_populate_sysroot', '/home/optee/var-fsl-yocto/sources/poky/meta/recipes-devtools/gcc/gcc-runtime_13.3.bb:do_populate_sysroot', '/home/optee/var-fsl-yocto/sources/poky/meta/recipes-devtools/quilt/quilt-native_0.67.bb:do_populate_sysroot', 'virtual:native:/home/optee/var-fsl-yocto/sources/poky/meta/recipes-devtools/patch/patch_2.7.6.bb:do_populate_sysroot', 'virtual:native:/home/optee/var-fsl-yocto/sources/poky/meta/recipes-devtools/pseudo/pseudo_git.bb:do_populate_sysroot', 'virtual:native:/home/optee/var-fsl-yocto/sources/poky/meta/recipes-devtools/python/python3-pycryptodome_3.20.0.bb:do_populate_sysroot', 'virtual:native:/home/optee/var-fsl-yocto/sources/poky/meta/recipes-devtools/python/python3_3.12.6.bb:do_populate_sysroot']
| NOTE: Installed into sysroot: []
| NOTE: Skipping as already exists in sysroot: ['optee-client', 'optee-os', 'base-files', 'base-passwd', 'gettext-minimal-native', 'glibc', 'libxcrypt', 'util-linux-libuuid', 'zlib', 'binutils-cross-aarch64', 'cmake-native', 'gcc-cross-aarch64', 'gcc-runtime', 'libgcc', 'libtool-native', 'm4-native', 'opkg-utils', 'quilt-native', 'cracklib', 'libpam', 'shadow-sysroot', 'shadow', 'texinfo-dummy-native', 'linux-libc-headers', 'attr', 'openssl-native', 'expat-native', 'ncurses-native', 'util-linux-libuuid-native', 'zlib-native', 'flex-native', 'gnu-config-native', 'libedit-native', 'make-native', 'patch-native', 'perl-native', 'pseudo-native', 'python3-build-native', 'python3-cffi-native', 'python3-flit-core-native', 'python3-installer-native', 'python3-packaging-native', 'python3-pycparser-native', 'python3-pycryptodome-native', 'python3-pyproject-hooks-native', 'python3-setuptools-native', 'python3-wheel-native', 'python3-native', 'bzip2-native', 'libnsl2-native', 'libtirpc-native', 'shadow-native', 'unzip-native', 'xz-native', 'zstd-native', 'attr-native', 'gdbm-native', 'gmp-native', 'libbsd-native', 'libffi-native', 'libmd-native', 'libmpc-native', 'mpfr-native', 'sqlite3-native']
| DEBUG: Python function extend_recipe_sysroot finished
| DEBUG: Executing shell function do_install
| install: cannot stat '/home/optee/var-fsl-yocto/build_xwayland/tmp/work/imx8mn_var_som-poky-linux/optee-examples/4.7.0/build/ta/*': No such file or directory
| WARNING: exit code 1 from a shell command.
ERROR: Task (/home/optee/var-fsl-yocto/sources/meta-imx/meta-imx-bsp/recipes-security/optee/optee-examples_4.7.0.bb:do_install) failed with exit code '1'
DEBUG: Teardown for bitbake-worker
NOTE: Tasks Summary: Attempted 1508 tasks of which 1507 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
DEBUG: Executing python function buildhistory_write_sigs
DEBUG: Python function buildhistory_write_sigs finished
DEBUG: Executing shell function buildhistory_commit
DEBUG: Shell function buildhistory_commit finished
NOTE: Writing buildhistory took: 5 seconds
Summary: 1 task failed:
Summary: There were 2 WARNING messages.
Summary: There was 1 ERROR message, returning a non-zero exit code.
I am stuck:
  • there is no * file in the location /home/optee/var-fsl-yocto/build_xwayland/tmp/work/imx8mn_var_som-poky-linux/optee-examples/4.7.0/build/ta/*'
  • I don't know what type of file it's looking for to create one
  • It doesn't solve the do_install error either
Any help is appreciated.
4 返答(返信)
1,757件の閲覧回数
Harvey021
Please try to keep the versions consistent. The default BSP includes an optee file and example recipes for reference.
Harvey
1,747件の閲覧回数
YY34173
Thanks! If the default bsp includes optee examples, how would I access those without bitbake optee-examples? My goal is to use the examples to help build a TA for a use case I have.
1,742件の閲覧回数
YY34173
To add on, since I can't edit my original reply. All the other optee files I was able to build successfully.So if there's a way to access the optee examples if they are included, that would be optimal.
There's something within Scarthgap that really doesn't like optee-examples. I was able to find the 4.4 version of optee-examples and I still got an error:
| install: cannot stat '/home/optee/var-fsl-yocto/build_xwayland/tmp/work/imx8mn_var_som-poky-linux/optee-examples/4.4.0/build/ta/*': No such file or directory
ERROR: Task (/home/optee/var-fsl-yocto/sources/meta-imx/meta-imx-bsp/recipes-security/optee/optee-examples_4.4.0.bb:do_install) failed with exit code '1'
1,631件の閲覧回数
Harvey021
We don't provide optee examples. I tried to base on the BSP-6.6.52 and reference to the examples to modify, the build successes on my side.
%3CLINGO-SUB%20id%3D%22lingo-sub-2184346%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EOPTEE%E3%81%AE%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184346%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81Scarthgap%20%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%20Var-som-mx8m-nano%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20Yocto%20%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%EF%BC%88%20%3CA%20href%3D%22https%3A%2F%2Fdev.variscite.com%2Fvar-som-mx8m-nano%2Fmx8mn-yocto-scarthgap-6.6.52_2.2.0-v1.1%2Fyocto-build-release%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fdev.variscite.com%2Fvar-som-mx8m-nano%2Fmx8mn-yocto-scarthgap-6.6.52_2.2.0-v1.1%2Fyocto-build-release%2F%3C%2FA%3E%20%EF%BC%89%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E5%BE%93%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%3A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FBuilding-optee-examples-and-trusted-Apps-in-Yocto-bitbake%2Fm-p%2F1383425%2Fhighlight%2Ftrue%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors%2FBuilding-optee-examples-and-trusted-Apps-in-Yocto-bitbake%2Fmp%2F1383425%2Fhighlight%2Ftrue%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%AF%E5%8F%A4%E3%81%84%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81Optee-examples%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B34.7%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%80%81.bb%E3%81%AB%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E3%81%82%E3%82%8B%E6%83%85%E5%A0%B1%E3%82%92%E5%90%AB%E3%82%80%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%82%E5%9B%9E%E7%AD%94%E3%81%AE%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AF%E5%BB%83%E6%AD%A2%E3%81%95%E3%82%8C%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E5%85%AC%E5%BC%8F%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%20local.conf%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%B7%A8%E9%9B%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E6%AE%8B%E3%82%8A%E3%81%AE%20optee%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%204.4%20%E3%81%A7%E3%81%99%E3%80%82.bb%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%9B%E3%81%9A%E3%81%ABoptee-examples%E3%82%92bitbake%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%8C%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Ebitbake%20-DDD%20optee-examples%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20do_install%20%E3%81%AE%E3%83%8D%E3%83%83%E3%83%88%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%92%E7%84%A1%E5%8A%B9%E3%81%AB%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20SOURCE_DATE_EPOCH%3A%201627299039%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20do_install%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20optee-examples-4.7.0-r0%20do_install%3A%20Python%E9%96%A2%E6%95%B0%20extend_recipe_sysroot%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20optee-examples-4.7.0-r0%20do_install%3A%20Python%20%E9%96%A2%E6%95%B0%20extend_recipe_sysroot%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20optee-examples-4.7.0-r0%20do_install%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%E9%96%A2%E6%95%B0%20do_install%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20optee-examples-4.7.0-r0%20do_install%3A%20ExecutionError('%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Foptee%2Fvar-fsl-Yocto%2Fbuild_xwayland%2Ftmp%2Fwork%2Fimx8mn_var_som-poky-Linux%2Foptee-examples%2F4.7.0%2Ftemp%2Frun.do_install.53250'%2C%201%2C%20None%2C%20None)%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E5%A4%B1%E6%95%97%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%20%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Foptee%2Fvar-fsl-Yocto%2Fbuild_xwayland%2Ftmp%2Fwork%2Fimx8mn_var_som-poky-Linux%2Foptee-examples%2F4.7.0%2Ftemp%2Flog.do_install.53250%3CBR%20%2F%3E%E3%83%AD%E3%82%B0%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%3A%3CBR%20%2F%3E%20%7C%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20Python%E9%96%A2%E6%95%B0%20extend_recipe_sysroot%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7C%20%E6%B3%A8%3A%20%E7%9B%B4%E6%8E%A5%E3%81%AE%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%81%AF%20%5B'%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Foptee%2Fvar-fsl-Yocto%2Fsources%2Fmeta-imx%2Fmeta-imx-bsp%2Frecipes-%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%2Foptee%2Foptee-client_4.4.0.imx.bb%3Ado_populate_sysroot'%20%E3%81%A7%E3%81%99%E3%80%82'%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Foptee%2Fvar-fsl-Yocto%2Fsources%2Fmeta-imx%2Fmeta-imx-bsp%2Frecipes-%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%2Foptee%2Foptee-os_4.4.0.imx.bb%3Ado_populate_sysroot'%2C'%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Foptee%2Fvar-fsl-Yocto%2Fsources%2Fpoky%2Fmeta%2Frecipes-core%2Fglibc%2Fglibc_2.39.bb%3Ado_populate_sysroot'%2C%20'%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Foptee%2Fvar-fsl-Yocto%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fgcc%2Fgcc-cross_13.3.bb%3Ado_populate_sysroot'%2C'%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Foptee%2Fvar-fsl-Yocto%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fgcc%2Fgcc-runtime_13.3.bb%3Ado_populate_sysroot'%2C'%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Foptee%2Fvar-fsl-Yocto%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fquilt%2Fquilt-native_0.67.bb%3Ado_populate_sysroot'%E3%80%81%20'virtual%3Anative%3A%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Foptee%2Fvar-fsl-Yocto%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fpatch%2Fpatch_2.7.6.bb%3Ado_populate_sysroot'%E3%80%81'virtual%3Anative%3A%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Foptee%2Fvar-fsl-Yocto%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fpseudo%2Fpseudo_git.bb%3Ado_populate_sysroot'%2C'virtual%3Anative%3A%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Foptee%2Fvar-fsl-Yocto%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fpython%2Fpython3-pycryptodome_3.20.0.bb%3Ado_populate_sysroot'%2C%20'virtual%3Anative%3A%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Foptee%2Fvar-fsl-Yocto%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Fpython%2Fpython3_3.12.6.bb%3Ado_populate_sysroot'%5D%3CBR%20%2F%3E%7C%20%E6%B3%A8%E8%A8%98%3A%20sysroot%20%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3A%20%5B%5D%3CBR%20%2F%3E%20%7C%20%E6%B3%A8%E6%84%8F%3A%20sysroot%20%E3%81%AB%E6%97%A2%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%3A%20%5B'optee-client'%2C%20'optee-os'%2C%20'base-files'%2C%20'base-passwd'%2C%20'gettext-minimal-native'%2C%20'glibc'%2C%20'libxcrypt'%2C%20'util-linux-libuuid'%2C%20'zlib'%2C%20'binutils-cross-aarch64'%2C%20'cmake-native'%2C%20'gcc-cross-aarch64'%2C%20'gcc-runtime'%2C%20'libgcc'%2C%20'libtool-native'%2C%20'm4-native'%2C%20'opkg-utils'%2C%20'quilt-native'%2C%20'cracklib'%2C%20'libpam'%2C%20'shadow-sysroot'%2C%20'shadow'%2C%20'texinfo-dummy-native'%2C%20'linux-libc-headers'%2C%20'attr'%2C%20%E3%80%8Copenssl-native%E3%80%8D%E3%80%81%E3%80%8Cexpat-native%E3%80%8D%E3%80%81%E3%80%8Cncurses-native%E3%80%8D%E3%80%81%E3%80%8Cutil-linux-libuuid-native%E3%80%8D%E3%80%81%E3%80%8Czlib-native%E3%80%8D%E3%80%81%E3%80%8Cflex-native%E3%80%8D%E3%80%81%E3%80%8Cgnu-config-native%E3%80%8D%E3%80%81%E3%80%8Clibedit-native%E3%80%8D%E3%80%81%E3%80%8Cmake-native%E3%80%8D%E3%80%81%E3%80%8Cpatch-native%E3%80%8D%E3%80%81%E3%80%8Cperl-native%E3%80%8D%E3%80%81%E3%80%8Cpseudo-native%E3%80%8D%E3%80%81%E3%80%8Cpython3-build-native%E3%80%8D%E3%80%81%E3%80%8Cpython3-cffi-native%E3%80%8D%E3%80%81%E3%80%8Cpython3-flit-core-native%E3%80%8D%E3%80%81%E3%80%8Cpython3-installer-native%E3%80%8D%E3%80%81%E3%80%8Cpython3-packaging-native%E3%80%8D%E3%80%81%E3%80%8Cpython3-pycparser-native%E3%80%8D%E3%80%81%E3%80%8Cpython3-pycryptodome-native%E3%80%8D%E3%80%81%E3%80%8Cpython3-pyproject-hooks-native%E3%80%8D%20'python3-setuptools-native'%E3%80%81'python3-wheel-native'%E3%80%81'python3-native'%E3%80%81'bzip2-native'%E3%80%81'libnsl2-native'%E3%80%81'libtirpc-native'%E3%80%81'shadow-native'%E3%80%81'unzip-native'%E3%80%81'xz-native'%E3%80%81'zstd-native'%E3%80%81'attr-native'%E3%80%81'gdbm-native'%E3%80%81'gmp-native'%E3%80%81'libbsd-native'%E3%80%81'libffi-native'%E3%80%81'libmd-native'%E3%80%81'libmpc-native'%E3%80%81'mpfr-native'%E3%80%81'sqlite3-native'%5D%3CBR%20%2F%3E%20%7C%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20Python%20%E9%96%A2%E6%95%B0%20extend_recipe_sysroot%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%7C%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%E9%96%A2%E6%95%B0%20do_install%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7C%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3A%20'%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Foptee%2Fvar-fsl-yocto%2Fbuild_xwayland%2Ftmp%2Fwork%2Fimx8mn_var_som-poky-Linux%2Foptee-examples%2F4.7.0%2Fbuild%2Fta%2F*'%20%E3%82%92%E7%B5%B1%E8%A8%88%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%7C%20%E8%AD%A6%E5%91%8A%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8B%E3%82%89%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%201%20%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20(%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Foptee%2Fvar-fsl-Yocto%2Fsources%2Fmeta-imx%2Fmeta-imx-bsp%2Frecipes-%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%2Foptee%2Foptee-examples_4.7.0.bb%3Ado_install)%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%20'1'%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20bitbake-worker%20%E3%81%AE%E3%83%86%E3%82%A3%E3%82%A2%E3%83%80%E3%82%A6%E3%83%B3%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20bitbake-worker%20%E3%81%AE%E3%83%86%E3%82%A3%E3%82%A2%E3%83%80%E3%82%A6%E3%83%B3%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%3A%201508%20%E4%BB%B6%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%201507%20%E4%BB%B6%E3%81%AF%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%811%20%E4%BB%B6%E3%81%AF%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%83%93%E3%83%AB%E3%83%89%E5%B1%A5%E6%AD%B4%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20Python%E9%96%A2%E6%95%B0buildhistory_write_sigs%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20Python%20%E9%96%A2%E6%95%B0%20buildhistory_write_sigs%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%E9%96%A2%E6%95%B0%20buildhistory_commit%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%E9%96%A2%E6%95%B0%20buildhistory_commit%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E6%B3%A8%3A%20%E3%83%93%E3%83%AB%E3%83%89%E5%B1%A5%E6%AD%B4%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AB%E3%81%AF%205%20%E7%A7%92%E3%81%8B%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E6%A6%82%E8%A6%81%3A%201%20%E4%BB%B6%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Foptee%2Fvar-fsl-Yocto%2Fsources%2Fmeta-imx%2Fmeta-imx-bsp%2Frecipes-%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%2Foptee%2Foptee-examples_4.7.0.bb%3Ado_install%3CBR%20%2F%3E%E6%A6%82%E8%A6%81%3A%20%E8%AD%A6%E5%91%8A%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%202%20%E4%BB%B6%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%A6%82%E8%A6%81%3A%201%20%E3%81%A4%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%82%BC%E3%83%AD%E4%BB%A5%E5%A4%96%E3%81%AE%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%A1%8C%E3%81%8D%E8%A9%B0%E3%81%BE%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CUL%3E%3CLI%3E'%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Foptee%2Fvar-fsl-Yocto%2Fbuild_xwayland%2Ftmp%2Fwork%2Fimx8mn_var_som-poky-Linux%2Foptee-examples%2F4.7.0%2Fbuild%2Fta%2F*'%20%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%20*%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLI%3E%3CLI%3E%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E7%A8%AE%E9%A1%9E%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%AE%E3%81%8B%E5%88%86%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%3C%2FLI%3E%3CLI%3Edo_install%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%82%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%81%94%E5%8A%A9%E5%8A%9B%E3%82%82%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2189149%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20OPTEE%20Examples%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189149%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eoptee%20%E3%81%AE%E4%BE%8B%E3%81%AF%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AF%20BSP-6.6.52%20%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%97%E3%81%A6%3CA%20href%3D%22https%3A%2F%2Flayers.openembedded.org%2Flayerindex%2Frecipe%2F454137%2F%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%E4%BE%8B%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E5%A4%89%E6%9B%B4%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AE%E5%81%B4%E3%81%A7%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2185935%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20OPTEE%20Examples%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2185935%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%85%83%E3%81%AE%E8%BF%94%E4%BF%A1%E3%82%92%E7%B7%A8%E9%9B%86CAN%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BB%96%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20optee%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82SO%E3%80%81optee%20%E3%81%AE%E4%BE%8B%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E6%9C%80%E9%81%A9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EScarthgap%20%E3%81%AB%E3%81%AF%E3%80%81optee-examples%20%E3%82%92%E6%9C%AC%E5%BD%93%E3%81%AB%E5%A5%BD%E3%81%BE%E3%81%AA%E3%81%84%E4%BD%95%E3%81%8B%E3%81%8C%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82optee-examples%20%E3%81%AE%204.4%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FP%3E%3CP%3E%7C%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3A%20'%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Foptee%2Fvar-fsl-Yocto%2Fbuild_xwayland%2Ftmp%2Fwork%2Fimx8mn_var_som-poky-Linux%2Foptee-examples%2F4.4.0%2Fbuild%2Fta%2F*'%20%E3%82%92%20stat%20%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%7C%20%E8%AD%A6%E5%91%8A%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8B%E3%82%89%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%201%20%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%20(%2F%E3%83%9B%E3%83%BC%E3%83%A0%2Foptee%2Fvar-fsl-Yocto%2Fsources%2Fmeta-imx%2Fmeta-imx-bsp%2Frecipes-%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%2Foptee%2Foptee-examples_4.4.0.bb%3Ado_install)%20%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%20'1'%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2185904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20OPTEE%20Examples%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2185904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%20BSP%20%E3%81%AB%20optee%20%E3%81%AE%E4%BE%8B%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81bitbake%20optee-examples%20%E3%81%AA%E3%81%97%E3%81%A7%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E7%A7%81%E3%81%AE%E7%9B%AE%E6%A8%99%E3%81%AF%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E4%BE%8B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E8%87%AA%E5%88%86%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B9CASE%E3%81%AE%20TA%20%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2185554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20OPTEE%20Examples%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2185554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E4%B8%80%E8%B2%AB%E6%80%A7%E3%82%92%E4%BF%9D%E3%81%A4%E3%82%88%E3%81%86%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%20BSP%20%E3%81%AB%E3%81%AF%E3%80%81%E5%8F%82%E7%85%A7%E7%94%A8%E3%81%AE%20optee%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%83%AC%E3%82%B7%E3%83%94%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EHarvey%3C%2FP%3E%3C%2FLINGO-BODY%3E
