Not able to include metadata in RTSP stream
4,035 次查看
vinay_hasyagar
I am using IMX8Q Max and I want to insert metadata in RTSP streaming specifically in RTSP server. How exactly I can do that? My gstreamer pipeline is
"v4l2src  device=/dev/video3 ! videoconvert ! v4l2h264enc ! rtph264pay name=pay0"
I want to insert a string of user defined data in RTSP stream. I have tried an element called taginject but its of no use. I tried passing this pipeline to gst_bin_iterate_all_by_interface()API which returns those elements which support GstTagSetter interface. But none of the elements in my pipeline support GstTagSetterinterface. I tried using mux elements but those mux can not be linked to rtph264pay. I can't use any other encoding other than H.264. Please suggest any other methods to insert metadata
4 回复数
3,989 次查看
vinay_hasyagar
Hi ,
Is there any solution to this?
3,736 次查看
Udhay_
still not get it. did you find any solution how to insert metadata in gstreamer h264 plugins?
3,700 次查看
vinay_hasyagar
No. We could not include any metadata in RTSP stream. We achieved this by sending metadata packets through UDP sockets in a an interval.
Thank you
3,693 次查看
udhayamoorthi
Can you please tell me how you have added metadata in UDP sockets?
share it with me in [email protected]
