No caching decode for AAC audio with libfsl
1,370 次查看
hirokazuyamashi
Now we are planning to use "libfsl" as AAC decoder with real-time playback (needs to achieve very short latency).
According to our trial, "libfsl" decoder seems to hold decoded audio of about 40 ms samples even though AAC-LC was specified. Can I specify no cache option for AAC decode?
# I've read an attached document, but the document does not specify all options of its API...
Package name:     libfslcodec-3.0.11
Linked library:      lib_aac_dec_arm12_elinux.so
标签 (1)
标记 (1)
1 回复
1,278 次查看
joanxie
did you try the latency option in the gstreamer? If you need low-latency
RTSP streaming playback, you can set this property to a smaller value.
