Nitrogen6x Gstreamer
已解决
跳至解决方案
2,288 次查看
rashmib
Can anybody tell me , from where I can get the gstreamer source code to test on imx6 nitrogen6x board and which version of gstreamer should be used .
Rashmi
标签 (3)
1 解答
2,223 次查看
Hi Rashmi
seems one can look at
https://boundarydevices.com/gstreamer-imx-plugin-with-buildroot/
GitHub - Freescale/gstreamer-imx: GStreamer 1.0 plugins for i.MX platforms
or search https://boundarydevices.com/?s=Gstreamer
在原帖中查看解决方案
2 回复数
2,224 次查看
Hi Rashmi
2,223 次查看
rashmib
Hi igor,
Thanks for the reply.
Now I am able to use  gstreamer with  the build root image from the above link which you mentioned.
Now I want to test my own gstreamer application. Can you please let me know where I can get the toolchain which is used for the build root image.
Rashmi
