Need to use scfw_cli on kernel 6.1
已解决
跳至解决方案
2,127 次查看
mohamed-ali_fod
I want to use https://github.com/nxp-imx-support/scfw_cli/tree/master/Linux on kernel 6.1 but I cannot find header and source code for sc could you please help? I found it only on kernel 4.19.
Mohamed Ali
1 解答
2,104 次查看
Zhiming_Liu
Hi @mohamed-ali_fod
This cli is out of update and we have removed the kernel interface from L5.X.
You can try to copy these header from 4.19,but we can't confirm that this will work.
Best Regards
Zhiming
在原帖中查看解决方案
2 回复数
2,105 次查看
Zhiming_Liu
Hi @mohamed-ali_fod
Best Regards
Zhiming
2,077 次查看
mohamed-ali_fod
Hi @Zhiming_Liu,
Ok thank you for confirmation.
Mohamed Ali
