Need mipi-csi patch for imx8
5,115件の閲覧回数
wanbenzhou
Anyone could support the patch files for ds90ub962 with imx8 ?   the patch suit with mipi-csi part.
タグ(3)
7 返答(返信)
5,041件の閲覧回数
joanxie
unfortunately, don't find such patch for imx8
5,041件の閲覧回数
wanbenzhou
Thanks  I have linked to imx8.
Now, display  is unnormal, such as following,  sensor output format is RAW10 .
Could you help me?
5,041件の閲覧回数
joanxie
what imx8 product do you use? imx8qm?
5,041件の閲覧回数
wanbenzhou
Yes,   I used imx8qm-mek  board!
Kernel is    "imx_4.14.98_2.3.0"
5,041件の閲覧回数
joanxie
for raw data capture, maybe you can refer to my another case:
How to capture raw bayer data.
5,041件の閲覧回数
wanbenzhou
I  have read the case,  but I don't know  how to do the following operate " for capturing raw 10bits data, you need to  set RAW16 in ISI , and right shift 4bits to get the correct data. "  ,  which file   and whitch function?
5,011件の閲覧回数
joanxie
you need to do this job by yourself, when the data to the memory, you need to shift the bits by your own software, we don't have such sample code, for ISI settings, you can set the CHNL_IMG_CTRL, one also can refer to the document as below:
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-MX8QXP-capture-raw-bayer-data-and-deba...
