NXP i.mx8qxp usb serial GPS
napster_k
How to set an USB serial gps module as the default Gps data provider in the IMXQXP running on automotive android 12 . currently the usb shows up as ttyUSB0 in /dev , cat commands gives out nmea data . There is no gps implementation on the image i want to know how to set this up .
Thank you ..
Tags (2)
