NXP Virtualisation guide for Variscite Spear MX8
rishabh_modi
Hello , I have a Variscite SPEAR MX8 based on NXP I.MX8 quad max. I wanted to run android and linux simultaneously via XEN hypervisor by following the nxp virtualization guide document IMXVIRTUG.
Once i run the command
sudo ./uuu_imx_android_flash.sh -f imx8qm -d xen
it tells me that the only supported platforms are :
sabresd_6dq, sabreauto_6q, sabresd_6sx, evk_7ulp, sabresd_7d
evk_8mm, evk_8mq, aiy_8mq, mek_8q, mek_8q_car
How can I run this script to support the Variscite SPEAR MX8?
Chavira
Thank you for contacting NXP Support!
I tried by my side in iMX8MP-EVK and is working without problems, Unfortunately we don´t provide the software for the board that you are using, please try contacting Variscite SUpport.
Best Regards!
Chavira
