NTP Server Synchronization on LTIB 2.6.35 build
3,578 次查看
ijazfazily
I need to add support for NTP server synchronization on LTIB 2.6.35 build. Please let me know how to proceed with the same.
Iju
标签 (2)
5 回复数
3,430 次查看
Rita_Wang
I do not know which product you are using. For our now product we do not use the LTIB no more, we use the yocto. For the yocto setting you can refer to https://community.nxp.com/message/363069
3,430 次查看
ijazfazily
I really appreciate your response. We have network card, which has i.MX283 application processor running LTIB 2.6.35 build. This is actually a feature addition of an existing product. Please let me know if any reference links available for this requirement.
Thank you.
3,430 次查看
Rita_Wang
I will try my best to found some reference for you.
3,430 次查看
ijazfazily
Could you please update ?
ijaz
3,431 次查看
jimmychan
1. You may find the source code of your NTP server software package. (.tar.gz file)
2. Create a .spec file in the LTIB for configure,compile,deploy of this software package. You can refer to other .spec as an example.
3. Or you can compile the source code by the ARM toolchain and then install/copy the executable files to the rootfs directly.
