Modifying [email protected] in Yocto Build level
ashoksowndar
I want to modify [email protected] in the Yocto Build level, able to successfully modify that in userspace but need a solution to modify in Yocto.
Thanks in Advance.
Ashok
joanxie
you can refer to the yocto user guide:
$ git config --global user.name "Your Name"
$ git config --global user.email "Your Email"
$ git config --list
ashoksowndar
Hi @joanxie ,
I have checked Yocto user guide, but I am not able to find the relevant solution.
Can you please provide exact procedure to modify [email protected] in the yocto level.
Ashok
joanxie
did you check the chapter 4 Yocto Project Setup of yocto user guide? is it helpful for you? pls double check that
ashoksowndar
Yes @joanxie , I have checked the chapter 4 (Yocto Project Setup). It is about how to setup the Yocto Build Environment.
I have already successfully configured the Yocto environment in my PC and looking for way to modify only [email protected] in Yocto Build environment.
joanxie
what yocto build level you mean? what's your demands?
