Missing bluetooth (UART4) on Solidrun Hummingboard Pulse (iMX8)
1,450件の閲覧回数
garyg
According to Solidrun HB spec they used UBLOX BT module that connects to UART4. I can see the /dev/ttymxc3 but failed to see bluetoothctl controller.
Is there any driver that I need to install to expose it on user space? E.g. hciconfig hci0
1,401件の閲覧回数
jamesbone
Hello Gary,
I strongly suggest that you submit your question on the Solid Run Forum,
http://forum.solid-run.com/
Since the BSP that they are using it is different from the NXP official release for the  i.MX8M EVK board.
