Mipi serial clock frequency
kapilkumar
Hello..
i just want to interface an mipi display with imx6 processor using only two data lanes.For that i want to know how maximum the  clock frequency will be in the serial clock and data line used for LCD if . how to find it ?
Thank You.
Kapil
joanxie
pls refer to the chapter 41 of Reference Manual, I send the link to you
<http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6DQRM.pdf?fpsp=1&WT_TYPE=Reference Manuals&WT_VENDOR=FREESCALE&WT_FILE_FORMAT=pdf&WT_ASSET=Documentation&fileExt=.pdf>.
