Mfgtool2 conga-QMX6 example
2,674件の閲覧回数
j-g
Are there any examples available on how to use mfgtool2 to write Linux kernel/rootfs to the onboard emmc on the conga-QMX6?  Meaning what to put in to ucl2.xml.  Thanks!
タグ(2)
2,441件の閲覧回数
SergioSolis
We do not have documentation on how to flash a conga board, we have a couple of documents that explain the UCL usage, tough I'm not sure if it'll work with a non-freescale board.
It should be intestresting to know the results...
Both documents are attached...
2,441件の閲覧回数
j-g
Thank you for the information.
