Messaging Unit mapping in imx8qm
3,874件の閲覧回数
bghiggins
The IMX8QM manual does a lot to describe the how the Message Unit works IO between Core A and Core B, but it doesn't really describe which MU A are connected to which MU B.  From what I can tell, it seems to be a one to one connection, but I could be wrong.  How can I tell what the MU connections are between the different domains?
タグ(2)
3,838件の閲覧回数
Harvey021
Such documentation(DSC) that I can't access too. You need to contact Local NXP FAE or marketing team to get it.
Harvey
Harvey
5 返答(返信)
3,850件の閲覧回数
bghiggins
It seems the MUs connections are controlled by the DSC (Distributed Slave System Controller).  Is there documentation for that or is that also something I need to get from ARM?
3,839件の閲覧回数
Harvey021
Harvey
Harvey
3,812件の閲覧回数
bghiggins
Is there a good point of contact for the marketing and/or FAE teams?
3,801件の閲覧回数
Harvey021
A better way to reach out your local DFAE, if you know someone who is the one supports for you.
Harvey
3,858件の閲覧回数
Harvey021
Hi @bghiggins
MU is a group of AB, but we have many MUs, such as MU1, MU2, MU3, so for MU1, MU1_A is the one that communicates with MU1_B.
Since the Arch and IP belong to ARM, I would recommend you to refer to ARM sources for more details.
Harvey
