Memory leak in gstreamer appsrc running in imx7 sabre board
990件の閲覧回数
Ananth
Hi All,
 When i run a sample application of gstreamer appsrc example code in x86 machine and imx7 sabre board, i was able to visualize memory leak in the sabre board but not able to visualize the memory leak in x86 machine. Attached code for your reference. Is this a known issue ? Any workarounds/patch available for the memory leak ?
Thanks and regards,
Ananth
0 返答(返信)
