Measure memory bandwidth to GPU
ソリューションへジャンプ
2,715件の閲覧回数
yuansong
I'm trying to figure out a good way to measure memory bandwidth to GPU when I run OpenGL ES applications (with shaders) on my i.MX6 DL board. I could estimate it by calculating pixels and fps. But I wonder how much data is precisely copied to the Vivante GPU and back as it executes shaders.
It would be great if anyone can share your idea about how this can be done :-)
タグ(1)
2,267件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
Re: Measure memory bandwidth to GPU
Andre SilvaEmployee
I was investigating your question and I ended up that your suggestion is the best one, we do have a tool from vivante, but it is for internal use only and can´t be released to anybody outside FSL.
2 返答(返信)
2,267件の閲覧回数
andre_silva
I believe we already have a tool from vivante that can provide you this information, I will check if it is already available and let you know.
regards,
andre
2,268件の閲覧回数
karina_valencia
NXP Apps Support
NXP Apps Support
Andre SilvaEmployee
