Making cpu reset cause available from U-Boot to Linux
1,944 次查看
colinhelliwell
I'd like the system's reset cause (por, watchdog etc) to be available to Linux - it's shown in the u-boot debug e.g.
"Reset cause: POR"
I've only found a few references to this in searching, and it seems that u-boot clears the register after reading?
Has anyone done any modifications to preserve this, and then been able to read it from the OS?
标签 (4)
1 回复
1,394 次查看
Hi colinhelliwell
seems you are right, in general one can save that reset info in some
of SRC_GPR registers and use in linux.
