MX6Q SPI SLAVE MODIFY
piterzheng
HI!
I use MX6Q sabreauto version, the kernel using Linux - 3.0.35.I have SPI1 / SPI2 / SPI5, now I'm going to do with SPI2 MASTER, other SLAVE.
I was according to the attachment "SPI_SLAVE.7z.zip" to modify
My configuration is as follows:
CONFIG_IMX6_SDP_MISCSPI=y
CONFIG_SPI_IMX_VER_2_3=y
#CONFIG_SPI_IMX_VER_2_3_SLAVE is not set
This is correct?
AND I use MCU connect the board.how do i test?
The MCU is in the attachment “USB2uis转接板用户手册(多功能版)R30.pdf”
Wire connection way:
MISO - MISO,
MOSI MOSI -- -
SS - SS
CLK - CLK
GND - GND
Data is read 0 XFF.
MISO MOSI -- -
MOSI MISO -- -
SS - SS
CLK - CLK
GND - GND
Data is read 0 x00.
Can you help me?I need your help very much.Thank you
Original Attachment has been moved to: SPI_SLAVE.7z.zip
Labels (4)
Tags (3)
Rita_Wang
Hi piter,
I see that your question is about i.mx processor. I recommend you to move your question to i.MX Community. So that our i.mx export can reply to you.
Have a nice day.
Best Regards
Dan
