MQS example for MX RT1024
rexrothppc
Hi, I have to configurate MQS (medium audio quolity DAC) for RT1024. But there are no demos example. Does anybody help me? As I understand - I have to init SAI3, and some special registers. I found some example in china forum but it not works.
I put my code. Actually SAI interface complicate to anderstand, may somebody help me?
rexrothppc
Problem is solved, I am just select wrong pin
Atached work McuXpresso project.
If something not correct, tell me too, thanks
RaRo
Hello @rexrothppc,
Good to hear you find a workaround.
For more information, you could check the following information about the MQS that could be useful:
Best regards, Raul.
